Justin
Boot Rattles!
Justin
Is there anything I can do to stop the tailgate knocking over bumps guys? It feels quite loose when it's closed and you push down on it. With the state of the s*ite Oxfordshire roads it's driving me crazy, banging away behind me.
Ta.
Justin.
RichE
Open the boot, and look up at the corners.
Two rubber boots, one on each side.
Turn them, they screw in/out. Adjust as necessary.
nick
You can also adjust the striker plate on the body to tighten it up a bit.
Undo the two 11mm bolts holding the striker plate and move it down slightly.
Nick
Justin
Cheers guys.
Kind of obivous really :rolleyes:
Much better now.
Justin.
Guest seb
Yep, in my old gti adjusting the striker plate was the best mod I ever did :rolleyes:
