surfer69
Spare wheel carrier
surfer69
Hi everyone,right,I’ve just had to remove my spare wheel carrier but to remove it I had to remove a plastic clip to allow me to lift the hinged side up and to the side to drop it down.On removing the plastic clip it snapped.Any ideas on where to get another one or even what it’s called.Huge thanks in advance.
It might be available from the main dealer, I've never tried. A bolt and nyloc nut and a couple of washers fitted in the loop will perform the same job and stop the cage from being able to get out.
Gohn
part number's #761906 if you can order it
or mine was missing when purchased a few years ago
I cut a rubber wedge and its good
