ArthurH 7 Posted January 29 We are just about to make a new set of brake pipes for the 205GTI. I have a flare tool; I'll buy some tubing and a bag of unions. The championship rules constrain us to use the standard calipers and rear cylinders. To save me checking each one individually, are all the OEM brake threads 'standerdised' across the car (including the master cylinder)? E.g., M8 everywhere? Any good tips before I start? Share this post Link to post Share on other sites
welshpug 1,666 Posted January 29 Mostly M10x1.0, a 1.9 will have a pair of 12x1.0 into one side of the brake pressure limters 1 Share this post Link to post Share on other sites
petert 597 Posted Thursday at 06:19 AM (edited) Can you manage a double flare though? I single flare would surely be illegal? I've approached this a bit differently and changed to 3AN hose where appropriate/possible. Here are some Speedflow part numbers you might find useful: T200-C03 200 series -3 hose Teflon® Stainless Steel Braided Hose 260-03 life saver 380-03 1/8 NPT adaptor 344-03 dual seat 201-03 straight hose ends https://www.speedflowdirect.com.au/ You probably have a similar supplier in the UK. And if you do it stainless fittings, hose and lines, you'll have no issues with corrosion. Edited Thursday at 06:27 AM by petert 1 Share this post Link to post Share on other sites
ArthurH 7 Posted Thursday at 07:55 AM Thanks Peter, just for the avoidance of doubt :-), you are using the braided hose throughout the braking system, i.e., no rigid pipe at all? If so, the brake pedal feel is not more spongy? Share this post Link to post Share on other sites
petert 597 Posted Thursday at 08:26 AM No, I use hard lines on the straight parts, but around the difficult to bend parts, I'm using the stainless teflon hose. Even just changing to stainless teflon hose, replacing rubber hoses will improve the pedal feel. I did that on my road 306. I have a friend who did his entire 206 GTi180 in stainless teflon hose and the pedal feel is magnificent. 1 Share this post Link to post Share on other sites
ArthurH 7 Posted Saturday at 07:35 AM I think we may follow your lead and go for a hybrid solution. Picking up from Mei, I think we will have M10x1 throughout - except for the two sides of the Willwood bias valve (1/8NPT?) Share this post Link to post Share on other sites
ArthurH 7 Posted 11 hours ago Now I am looking at this in more detail, I am uncertain what sort of 'flare' we need. Just using these two listings from the same seller as a convenient example, one says "convex" flare, and the other (a different price) "straight", but I am struggling to see the difference. https://www.ebay.co.uk/itm/146306095109 https://www.ebay.co.uk/itm/146103209481 Share this post Link to post Share on other sites
welshpug 1,666 Posted 5 hours ago Those two fittings look the same to me The typical flare on european cars is a DIN single flare, mushroom shaped, rather than the american SAE bubble flare. You wouldn't buy those fittings to connect to the hard lines anyway, the car side of flexible lines are female fittings with a groove for a clip, the rear lines from body to axle is female both ends other than the left side on a 1.6 that had a male fitting screwing directly onto a Tee secured to the body on a stud. 1 Share this post Link to post Share on other sites
ArthurH 7 Posted 5 hours ago Thanks Mei, I was considering following Peter's suggestion above of dispensing with the hard lines altogether, but I'm still undecided. Can I infer from what you say that they would be suitable to join braided PTFE hose to the calipers, master cylinder and slave cylinders? Share this post Link to post Share on other sites
Bremar 2 Posted 59 minutes ago (edited) I thought double flared brake pipes were the American standard and are the safest, the European standard is bubble flares and single flared are just not safe enough for brake systems. Flaring steel brake pipes is too difficult to DIY in steel so next best IMHO is copper nickel pipes which are harder than copper (which I cant imagine are acceptable in racing but maybe they are ) but still easily bendable. Just buy a flaring tool and practice until you get the double flare right. There are plenty of YouTube vids on making up brake pipes with double flares. Bremar Edited 1 minute ago by Bremar Share this post Link to post Share on other sites
Bremar 2 Posted 40 minutes ago From left to right. Single flare, double flare and bubble glare. Share this post Link to post Share on other sites
