soundguy
Yellow Instrument Cluster Connector (PH2?)
soundguy
When I look at this article
https://www.205gtidrivers.com/articles/articles-guides/body-interior-ice/instrument-panel-explained-r46/
this appears to be for the PH1 cluster - blue plastic flexible circuit, mine has the green flexi circuit.
For instance on my yellow block the second pin is for the fuel gauge - in the article fuel gauge is pin 6.
Any ideas what that the first pin is on the instrument yellow block is please? Its a pale blue/pale turquoise wire.
Can you find a number on the wire?
g
soundguy
Nothing on it. I've accidentally pulled the other end of the wire out of whatever it was wired into, and my yellow block has been cut from another loom + transplanted into mine. I'm assuming the first wire into the yellow block was actually pale blue/green/turquoise because mine is connected to a red wire with a barrel connector, which then connected to the yellow block.
If I can find where the pale blue/green/turquoise wire connects to and from, hopefully I can get the instruments to work properly without over reading + moving in time with the indicators. At least, it would be something to cross off the list.
PhilNW
Is this any good? might to do a bit of translating.. Yellow plug has the 8 pins/connectors if my records are correct
ob_426f76_51-1-connecteurs-sur-combine.j
There are other wiring diagrams here
http://prepparts.free.fr/docs/doc2ter.html
Edited by PhilNW
  • Thanks 1
soundguy
Belated thanks to PhilNW, I'm only a month late - don't be mad!
Bremar
Still trying to fix my fuel level sender issues but thought someone might be interested in googles english translation of  the above connector identification chart
“Temoin Prechaufiage” doesn’t translate on the chart but its the glow plug lamp connection.
thanks Bremar
Edited by Bremar
soundguy
Thanks for the translation
