ATK
Anyone used repro rear quarter window seals from Youngtimers?
ATK
As above - how have you found them?
i bought a set - not cheap - and the fit was terrible, not much bigger than used ones and haven’t kept the rain out.
got a set on order from the Peugeot museum instead so hopefully they will be better!
sp_en_ny
For my cab i bought new window seals front and back and door seals which were far from being cheap, they are a huge improvement on the originals i took off as had shrunk and cosmetically ruined. I still have some gaps so not perfect but much better then what was there and the only place that had them in the 8 years of owning the car.
I would certainly use them again based on this experience.
I bought a set of the Youngtimer ones a few weeks back, which arrived within a week despite the pessimistic timescales displayed on the site.
They're certainly miles better than any of the original, shrunken seals I had and the water ingress has slowed considerably, but frustratingly hasn't disappeared completely - not immediately clear whether water is still coming past the seals somehow or (as I suspect) there's actually another leak somewhere, given that the seals themselves are bone dry after heavy rain.
Is the fit perfect and am I completely satisfied with them? No - I would say that they probably need to be about another 5-10mm long as they don't quite fully butt up in the corners, and I'm not entirely convinced that the profile is correct as the quarter window has noticeable resistance closing now and the seal sort of "muffin tops" out and around the glass as the window closes, both of which I can't see being how they would have been brand new out of the factory.
Be interesting to see how you find the Peugeot museum supplied seals - I was debating getting them, but couldn't really justify the near doubling of cost when, at least up until then, I hadn't heard anything bad about the YT repro seals.
ATK
Totally with you on all points here Anthony - the profile on the YT seals isn’t quite right and they bulge at the corner on the outside, and as you say don’t butt up in the corners correctly. And the mating face of the seal isn’t a very good profile.
will post back once the museum seals arrive but I’m sure they are going to be much better!
my youngtimers seals leak so much I’ve had to take the car off daily duties.
where are you getting your leak coming in Anthony?  Mine is collecting in the channel immediately below the window. I suspect the seam of the window along the bottom needs sealing as I can feel wetness all along the bottom of the window seam if that makes sense. This was the case before I put the youngtimers seals on.
ATK
Seals arrived from Peugeot Museum (inc £56 import tax - argh!)
yet to fit but look identical to originals so fingers crossed!
ScoobyJawa
I got mine a while back from the museum too, they look identical to oem, but not yet needed to fit. I also got the front seals which are the same and on the passenger side seems to have fixed the leak I had in the passenger footwell.
