ArthurH
Dash Wiring Questions
ArthurH
I'm building a new loom for our car.  I'm retaining the original gauges, so I am starting with Zoldalma's excellent 'article' - Instrument Panel Explained - from 2002!
Most of it makes complete sense to me, but I am confused by having two pins for the oil temp: A1 is the Warning light and A7 is the Signal.  Can someone please expand on this?  Similarly two separate pins for for the coolant temp and another two for oil pressure.
Again, D6 is the Fuel level sensor and D7 is the Low fuel warning light.  Are there two wires from the sensor?
other than the fuel sender each sensor is a single wire, earth through the body of the sensor, obviously with a petrol tank the fuel level sender needs and earth, and has the low level switch built into the same module.
there is no oil high temp warning.
  • Thanks 1
ArthurH
Thanks Mei.  Apart from the fuel sender, that is pretty much what I thought.  So, does the single wire from the oil temp sensor in the sump connect to A7 and not A1?
ArthurH
A related question... Does anyone know what current (or wattage) the starter motor solenoid draws?  Obvs not the starter motor :-)  I am finding dramatically varying results on the interweb when I search for this.
Similarly, each of the two fuel pumps?
ArthurH
Also :-)    My rev counter connector (Blue) has one more connection than shown in the article above.  Next to the rev counter wire in '3', I have a yellow wire in '4'.  The labeling in the wire isn't very clear - it could be j28 or even T23
Does anyone know where this goes to?  As it happens, I will be using an output from the Emerald Tacho driver module, but I still would like to know what this wire does.
ArthurH
More :-)  The plug on the Wiper motor has 5 wires.  Black Red, Blue, White and Grey IIRC.  Does anyone know what each of these wires does?
I believe they work as follows.
Full speed.
Slower.
Intermittent.
Trigger for park
Earth.
  • Thanks 1
ArthurH
Now that I have finally come to wire up the dash (having spent literally weeks on the wiper autopark :rolleyes:) I have discovered that my dash connector wiring differs from that posted by Zoldalma above.  Many of the wires he describes are simply missing from mine, but I don't think mine has been modified or tampered with.  Could someone please post a photo of the back of a Gti instrument cluster - but with the edge connectors still in place so I can see the wire colours?
TiA
ArthurH
This is what my own dash and connectors look like:
The fourth connector is grey (not yellow) but I doubt that matters.   Zoldalma describes these five connections as 'Ground':  A5, A10, B8, C4, D8.    Where I am currently concerned, is that only one of those is present in my connectors.  A yellow wire in B8 - which doesn't look like a ground.  The Tacho connector does have a black ground connection at E3, but I doubt that is used for the whole cluster.
ArthurH
To my surprise, I have managed to work out which of the connectors I need to do what I require from the dash.  The only one I am struggling with is the dash illumination.  According to Haynes, this is wire 14  (green connector #4), I have this wire and indeed, it used to go to the dimmer.  But if I provide 12v directly to G4 nothing lights up.  I want to buzz it backward from the bulb 'socket' on the PCB but, embarrassingly, I can't tell which bulbs provide the dash illumination (as opposed to warning lights).  Could somebody please mark up my photo above?  TiA
