MrStock
1.9 GTI 102 HP Where to get new injectors?
MrStock
Hi i have bad emissions and fuel in cylinders, ecu says "injectors". Where to buy new one? The chinese ones on ebay and amazon looks like problems
SRDT
ECU says? only the 122 hp Motronic ECU has onboard diagnostic.
You can source DFZ (XU9J1) injectors from Peugeot classic:
https://www.boutique-laventure-association.com/en/peugeot/3388-injector.html
They also have DKZ (XU9JAZ) injectors but other serious retailers have them for cheaper.
https://www.boutique-laventure-association.com/en/peugeot/14621-engine-injector.html
MrStock
Hello, thx for your reply. My car is an 1990 122 hp 1.9, but someone put an 102 hp block into it with head and everything from the original engine. It pulls around 115 hp on dyno and works well since 15 years, i have yellow injectors in it.
Do i have to take yellow injectors again?
Edited by MrStock
If you are running the original 122 bhp ecu afm and injectors then yes, use the yellow injectors or a replacement,  which according to peugeot museum are on the 2nd link
With the 102 bottom end and 122 bhp cylinder head you will have quite a lot more compression than a standard 128 bhp engine!    Or was it the bare block?  Pistons also from original engine?
Oh and 0280156045 is £37 on Autodoc,  under half the peugeot price!
MrStock
Thanks i bought them!
