Telf 235 2 Cars Posted July 31, 2024 Any body any idea what this noise might be? I can't find anything rubbing etc, its driving me slightly mad! 20240731_150916.mp4 Share this post Link to post Share on other sites
pugdamo 112 2 Cars Posted July 31, 2024 Shock bolts not tight enough bottom doesn't appear to be moving but maybe the top one although worth checking both, or anti roll bar end plate not tight enough? Share this post Link to post Share on other sites
PhilNW 67 Posted August 1, 2024 (edited) Sounds tinny like somthing that is thin metal (heat shield?) rather than something heavy metal. Edit, safety strap to petrol tank? Edited August 1, 2024 by PhilNW Share this post Link to post Share on other sites
Leslie green 161 Posted August 1, 2024 (edited) Id check the top shock bolt holes on the silver bracket part are not oval which can happen if they have ever ran too loose , my shock mounts were scrap because of that , it sound quite a heavy knock . That noise would drive me nuts lol disconnecting the shock would eliminate it as a cause but you should be able to see or feel for any movement or wear in situ. Edited August 1, 2024 by Leslie green 1 Share this post Link to post Share on other sites
stef205 96 1 Cars Posted August 1, 2024 Arb end flag bolts loose or flag bolt hole has become slotted and bolt is pinging around inside 1 Share this post Link to post Share on other sites
Telf 235 2 Cars Posted August 2, 2024 Cheers chaps, I'm taking it apart this morning to see if I can find whatever it is. Hoping it's just a loose bolt tbh! Share this post Link to post Share on other sites
Telf 235 2 Cars Posted August 12, 2024 Well I had it up on jacks and couldn't find anything, nor could I make it rattle once it was off its wheels. I suspect something is loose or the shock struts are knackered but it will have to wait and join the queue of work it needs. i doubt I will find it until I take the whole assembly off the car and start taking it to bits. Share this post Link to post Share on other sites
PhilNW 67 Posted August 12, 2024 When you took the first audio was the car on the ground or jacks? Quick and dirty - with the car on the ground - Suggest just unbolt the tops of the shocks and bounce up and down on the back of the car. Share this post Link to post Share on other sites
Telf 235 2 Cars Posted August 12, 2024 It was on the ground. So full weight on wheels. Worth a try I'll have a go this week. Share this post Link to post Share on other sites
Telf 235 2 Cars Posted February 27, 2025 Unbelievably I still haven't solved this issue. having said that the car is just sitting doing nothing outside. Roads are too s*itty to drive on and it's too cold for me to be bothered messing around with it. Maybe I'm getting too old to own an old cart that always demands attention! lol Share this post Link to post Share on other sites
stewal 9 Posted February 28, 2025 Bit of a long shot but sounds very similar to the noise I had: the air filter cylindrical housing had lost a bolt and was banging against the rocker cover making that tinny noise. Share this post Link to post Share on other sites
Telf 235 2 Cars Posted March 3, 2025 hey yep its not that, its coming from the rear Share this post Link to post Share on other sites
