Dale 14 1 Cars Posted July 20 Sorry in advance if I've posted this I the wrong section. I'm looking for your knowledge on these please, are they 1.9 hubs? Share this post Link to post Share on other sites
Gohn 68 Posted July 20 - count the number of splines 25 splines for GTi 1.9 hub, 21 for base model hub - or measure the bearing diametre 82mm OD for GTi 1.9 hub, 72 for base model (the GTi 1.6 hub also has 21splines and 72mm bearing like the base model, only its deep offset so the centre rim is raised much higher from the mating face of the hub, about 30mm. don't think yours is that but it becomes obvious when you have the two versions side by side) Share this post Link to post Share on other sites
Dale 14 1 Cars Posted July 21 Thankyou Gohn, I'll check the measurement. I was originally thinking the numbers pressed on them would help me out but that just returned bump stop results. Big thanks to this site and you knowledge again!! Share this post Link to post Share on other sites
Dale 14 1 Cars Posted July 21 Yep 25 splines and 82 OD. Share this post Link to post Share on other sites
