Maxvdm 0 Posted July 1, 2024 Hi Guys, I recently picked up a pretty rough phase 1 205 that has had an XU10J4RS swap. The car has Jenveys, a pug10ff racing manifold, a Motec m84, GAZ golds, an SI steering rack, and a BE3 hybrid short-ratio box with a 4.4 CWP and 3j plate diff. It’s very rough, and the plan is to pinch the running gear from that car and put it into my '93 205, which has 350,000 km on the clock. The plan is to drop the engines and subframes out from underneath both cars and swap them over. This will be my first time dropping the subframe completely on the '93, so I was wondering how the engine and subframe are mated. Is it just the lower engine mount? The plumbing for cooling systems and power steering will be removed, as well as all the engine looms, but I was wondering if there might be anything to look out for and a very rough time estimate. I have only ever removed drivelines from old Land Rovers, so the 205 is fairly modern compared to those. Given that the XU10 is already fitted in a 205, I’m hoping I won’t have any clearance issues with the brake master or radiator. The donor car looks to have a different radiator in it already. Any tips would be greatly appreciated, and if you think I might be better off taking the engine out the top, let me know. Thanks! Quote Share this post Link to post Share on other sites
Maxvdm 0 Posted July 1, 2024 the two cars are below. Share this post Link to post Share on other sites
