greenclaws1975 4 1 Cars Posted June 16 Apologies if this has been covered before..what is the best aerial to fit to the 205. Does the 206 aerial fit ? My car had a hideous aftermarket chrome aerial and the cable had been fitted behind the headlining and was poking out so it had to go. Fortunately the old aerial cable was still in there so I was able to tie some string to it and pull it through.. Bought one of the cheap aerials of ebay...had to take the din plug of as it was too big to fit through the channel that goes down the A pillar. I took a photo inside the section above the sunblind .. the channel the cable goes in is barely big enough.. Got the new cable pulled through and sourced a screw on DIN plug for the radio...but the ebay cable is about 1/2 metre too short! Are longer aerial cables available with the ring that fits on the aerial or will I have to fit an extension to the lead ? Thanks all Share this post Link to post Share on other sites
