dante205 0 Posted May 27 Hello guys! I've recently bought the GTI gauges and was wondering if it would fit my 205 XS with the carburated TU3S engine. What should I consider for the swap? Is it even possible? Share this post Link to post Share on other sites
SRDT 171 Posted May 27 It was done more than once, often on 205 Rallyes. You need to look at your oil pan to see if you can screw the oil temp sensor, for the oil pressure sensor there isn't much room so it's often done with a relocating kit: 1 Share this post Link to post Share on other sites
dante205 0 Posted May 27 9 minutes ago, SRDT said: It was done more than once, often on 205 Rallyes. You need to look at your oil pan to see if you can screw the oil temp sensor, for the oil pressure sensor there isn't much room so it's often done with a relocating kit: Thanks for your response! Should I worry about the plugs or they fit right in? Share this post Link to post Share on other sites
