Spesh 31 1 Cars Posted November 11, 2023 Cannot downshift without blipping the throttle, upshift is absolutely perfect with no issue. Seems to get worse the more engine braking there is. This has been present since I last had the car apart for new engine where a new helix organic clutch kit was fitted and the gearbox stripped down to change a synchro (can't remember which I changed but it was only one of them). I also fitted a satchshift too. Any pointers on what it could be? Clutch seems to be correctly adjusted. It's extremely difficult to disengage gears on overrun but changes up easily. Share this post Link to post Share on other sites
welshpug 1,675 Posted November 12, 2023 What gear oil are you using? Check the satchshift isnt binding on anything, could be movement under load making things hit exhaust or bodywork. Have had a gti6 engine wear out a 3rd gear synchro when a gear rod was resting against the downpipe and would pop out under load! Share this post Link to post Share on other sites
Spesh 31 1 Cars Posted November 12, 2023 Millers CRX LS 75W90, the one that 3J reccomend for the diff. Used it before it made the changes without issue. Satchshift is good, been through it with a fine toothcomb and its all free and working as it should as far as I can see. The engine is on stews group n mounts so movement is very minimal I've got to pull the box apart again as the fill level hole has a hairline crack in it so i need to change the casing. Its such a frustrating issue made worse by a few changes at the same time making it hard to pin down. Share this post Link to post Share on other sites
welshpug 1,675 Posted November 12, 2023 I'd try 75w80, as thats what peugeot specify. Share this post Link to post Share on other sites
Spesh 31 1 Cars Posted November 12, 2023 I could, but it work previously perfectly with that oil which is what is absolutely puzzling Share this post Link to post Share on other sites
PhilNW 46 Posted November 12, 2023 Have you tried it while up on jacks? i.e with little load on the transmission other than the wheels spinning. Is the clutch actually disengaging? Share this post Link to post Share on other sites
Spesh 31 1 Cars Posted November 12, 2023 with little load it changes fine both ways, also changes up under any style of driving without issue. I'm not 100% on the clutch actually disengaging but I believe it is given how easy (and quick) upshifts are and the fact it goes into any gear whilst stationary without issue. I did try tightening the clutch just in case but this just resulted in slip without any improvement on downshift. Share this post Link to post Share on other sites
PhilNW 46 Posted November 12, 2023 By tightening the clutch what do you mean? I was thinking adjusting the clutch to give more pedal travel to open the clutch more in case it is warped or similar. Share this post Link to post Share on other sites
Spesh 31 1 Cars Posted November 13, 2023 As in remove all slack from the cable so it's 'tight' giving maximum travel. I'd hope nothing is warped, brand new helix competition organic clutch and ttv flywheel Share this post Link to post Share on other sites
PhilNW 46 Posted November 14, 2023 (edited) Have you set the clutch as per the manual, which makes it level with the brake pedal.? EDIT - This should give the normal amount of travel to release the clutch Need to slacken off the clutch cable to let the clutch pedal sit higher then the brake pedal and give more more movement on the pedal/clutch operating lever and more clearance for the clutch driven plate to spin. Edited November 14, 2023 by PhilNW Share this post Link to post Share on other sites
Tom Fenton 1,561 Posted November 14, 2023 It sounds to me like the clutch is dragging and not disengaging properly. Seeing as it only started when you replaced the clutch it could be that something isn’t right with it. Share this post Link to post Share on other sites
Spesh 31 1 Cars Posted December 7, 2023 Clutch was adjusted as per the manual yep. Thing is it wasn't just the clutch changed. The box was split and had new bearings/seals, satchshift and clutch but I agree the clutch is the most likely. Just not sure what is causing it to drag. Share this post Link to post Share on other sites
Spesh 31 1 Cars Posted December 8, 2023 (edited) Pulled the box today, everything looked ok aside from the release bearing fit on the fork was a bit pants. I'll get a vid tomorrow and post it but it seems like the release bearing isn't holding straight, its rotating slightly but is still perpendicular to the cluch fingers. edit This is the clutch I fitted https://www.peugeot-tuning-parts.co.uk/peugeot-405-mi16-1.9-helix-organic-clutch-kit Edited December 8, 2023 by Spesh add details Share this post Link to post Share on other sites
welshpug 1,675 Posted December 8, 2023 check the clutch fork matches the bushes you have fitted. Share this post Link to post Share on other sites
Spesh 31 1 Cars Posted December 9, 2023 Yup, correct ones in there and they were not changed as part of this work. Had the end casing off the box and all looks well internally, ignore previous comment about the release bearing being rubbish on the fork, found my old one and its the same. Only thing I've noted is that the old release bearing (valeo) is a smidge taller than the new one (Helix) PXL_20231209_184708455 by Mark Needs, on Flickr Share this post Link to post Share on other sites
welshpug 1,675 Posted December 9, 2023 (edited) There Are two heights of release bearing, 20.5 and 18.5. Dont recall when which was used, ma used the same ones too. Edited December 9, 2023 by welshpug Share this post Link to post Share on other sites
Spesh 31 1 Cars Posted December 10, 2023 Ok so they both end up at the same height when fitted, just the helix one is a little less secure as it's clips that go on the fork are quite rubbish to be fair. Clutch release arm had a J stamped on it so it's yellow bushes, again it's what was previously fitted. Still not found the cause Share this post Link to post Share on other sites
Spesh 31 1 Cars Posted January 11, 2024 does that look ok? Still can't find anything that could have caused it. Only thing I really found wrong was a lack of end float, managed to get it to 0.06 so still a teeny bit tight but 0.02 is naff all in my mind. Share this post Link to post Share on other sites
Spesh 31 1 Cars Posted July 1, 2024 Seems to be resolved now. not totally sure how but the gearbox casing was swapped out as it had a crack around the fill level bolt and also increased the endfloat on the input shaft as it was a little tight. Share this post Link to post Share on other sites
