ozillex 0 Posted August 6, 2023 Hello, I just got a 205 rallye The cable that releases the hood lock is not fixed anywhere, (like the black cover of the cable not the cable itself that gets pulled) so it won't pull when I use the lever inside the car Couldn't find anything around on how to fix the external part of the cable to the car chassis, so if someone can provide me some picture of theirs or explain me how it should be actually put for it to work I would really appreciate that. Thanks in advace, Rick Share this post Link to post Share on other sites
welshpug 1,656 Posted August 6, 2023 The black outer sheathing should have a clamp with a 10mm nut and bolt on it above the left headlamp, you can use this to take up any slack in the system. Share this post Link to post Share on other sites
