Steve205 15 1 Cars Posted February 27, 2023 Morning all. I have a frustrating problem. I have a phase 1.5 , 1989 1.6gti. Horn and rear window heater are not working. Changed fuse (no.8), no joy. Switched relay (green 1 on far roght of board) with same 1 on other side of fuse board, no joy. Relay clicks as it should. Light on rear window heater switch works but goes out when you push button. Does anyone know what's going on? Thanks. Stephen Share this post Link to post Share on other sites
SRDT 175 Posted February 27, 2023 Isn't the cig lighter also gone? Share this post Link to post Share on other sites
Steve205 15 1 Cars Posted February 27, 2023 Cigarette lighter is disconnected since I got car. Never connected it, French electrics are flakey enough without adding more to them. I'm assuming the 3 items ( rear window heater/ horn / lighter ) on this fuse are not working. The horn has been intermittent in past at times but was working fine til yesterday..... Stephen Share this post Link to post Share on other sites
SRDT 175 Posted February 27, 2023 Check the link on my post, it's a common problem. If you urgently need a working horn to pass inspection an in-line fuse holder and two crimped terminals can save the day, that's also a good way to confirm that the problem is on the fuse box. Share this post Link to post Share on other sites
Steve205 15 1 Cars Posted February 28, 2023 Thank you for that. Have read through link. Seems to be exactly the same problem as I have. Thank you. Stephen Share this post Link to post Share on other sites
Gaz D 6 Posted March 1, 2023 Have you tested for voltage at each end? Turn the rear heater switch on and measure the voltage at the terminals at either side of the rear screen Share this post Link to post Share on other sites
Steve205 15 1 Cars Posted March 2, 2023 Was driving car yesterday. Horn and rear window heater miraculously working again. Definitely seems to be sporadicly stopping. Looks more and more like the fuse board issue as linked by SRDT above. Will have to book her into an auto-electrician. The fuse board fix is way above my capabilities. I will probably blow everything else, if I try it myself. Hopefully he'll sort issue without causing more trouble. For now it's working......for now. Thanks again. Stephen Share this post Link to post Share on other sites
