David Simson
Air metering 1.9 GTI
David Simson
I have a 1.9 GTI.
It is running very rich and my trusted mechanic is unable t adjust the fuel / air mixture. It is also idling at 1,500 revs.
He advises me it is the air meter which is non-responsive.
I also need a fuel filer bracket.
And someone has fitted an aftermarket air filter and I want a standard one.
If anyone can help with sourcing these parts I would be very grateful.
Thank you
DamirGTI
If running rich , I'd try first with the new CTS (coolant temperature sensor , used as an ECU input for the fuel mixture) , it's cheap and will be worth replacing it anyways , and see what happens .. if still no good (rich) then try to play with the AFM (air flow meter) .
D
Edited by DamirGTI
