Richie-Van-GTi
TPS wiring
Richie-Van-GTi
My car has a throttle pot from an XU10JRS to drive an adaptronic ECU.
The signal is inverted, its high when closed, low when open. I swapped wires 1&3 but it stated the same? Can anyone advise what the correct polarity is on these pots when used with other ECU's
I can have a look on autodata to see if it gives the pin outputs on the original loom if that's what you're after?
g
