Richie-Van-GTi
Wasted spark igniter
Richie-Van-GTi
Does anyone know if the generic used wasted spark coil from a lot of pugs and citroens etc has its own igniter?
I have an adaptronic ECU but it specifically states the coil must have its own igniter?
no,  earlier ecu's like mp3.1 used an amplifier, later ones dont but have the same coil.
Richie-Van-GTi
Thanks for that, makes sense.
Will have a look for a wiring diagram for the mp3.1 set up. Guess its the same amp as the gti uses?
Edit: found the answer, No, single channel in GTi.
Ordered a VAG style wasted spark coil with built on igniter
Edited by Richie-Van-GTi
yeah its a different amplifier, same 7 pin plug but 2 channel
XU10J4 has two dual channel ignitors. As said, they look identical to single channel. Let me know if you need a wiring diagram.
Richie-Van-GTi
Hi Peter, can you send me that wiring diagram please, suspect i may need to swap back to the original coil and use ign amp so i can get my tacho working again
number of oem applications here that use them, first one in the thread, the S16, uses two.
Richie-Van-GTi
Excellent, thanks
Richie-Van-GTi
Ordered an S16 ignition amp.
Just looking at that diagram on autodata, not clear how i would wire that to run a wasted spark coil on a different ECU. I assumed there would be power to the amp but seems not, also both pins connected to the ecu are labelled as 1&4 or 2&3 in pin out but the diagram shows them as 1&3 2&4.  Also the 4 wires labelled as triggers on the pin out suggests to me the ecu is igniting sequentially?
Just need to confirm its the right amp to run a wasted spark? I dont need 2?
Here is the factory diagram. Hopefully identical to what Welshpug posted.
yeah exactly the same, S16 does run sequential as far as I know, they do have cam sensor and individual injector wiring.
 you'll only need one amplifier if you want to run wasted spark,  the coil is basically two separate circuits in one module, hence  the paired HT lead outputs.
Yes, power is supplied to each coil and the ignition module grounds the coil.
S16 and 2L Mi16 are indeed full sequential fuel and direct fire ignition.
I concur with Welshpug, you only need one module to run wasted spark. The ignition modules aren't intelligent however, thus you'll need to optimise the dwell in your ecu settings for the coil packs being used. You'd probably start at 3ms and use an oscilloscope to optimise the saturation time.
The S16 and Mi16 coils are notorious for being unreliable. They're also reasonably unique to that engine, thus demand a high price.
SRDT
The XU10J4 diagram can be confusing if you don't want to run sequential. Here is the XU10J2TE diagram, it's also a MP3.2 ECU but with wasted spark:
As for XU10J4 coils you can also find them on some Maserati...
a friends 993 them too.
Richie-Van-GTi
Ok, bought a new dual channel ignition amp, listed as fitting all sorts including s16.
Do they all need to be on a plate as a heat sink or is that just the alloy body gti ones?
DamirGTI
Absolutely yes , need to mount it on the alu. plate with some heat sink paste/jelly in between (smear some on the back side of the module) , otherwise it'll overheat and burn out .
D
  • Thanks 1
Richie-Van-GTi
Need to drag this back up.
I've finally got round to doing this.
Brand new bosch amplifier
This morning car running fine on the old set up. Swapped the wiring to the above diagrams, confirmed all wires have continuity wtc but got no spark on 1&4.
Its a known good coil, ecu is still sending the same wasted spark signal.
Could it be ignition amp failure, are any of them wired different?
I have
Amp pin 1 to coil pin 1
Amp pin 2 to ecu trigger for 1&4
Amp pin 4 to earth
Amp pin 6 to coil pin 2
Amp pin 7 to ecu trigger for 2&3
Then
Coil pin 3 to live
Coil pin 4 to earth via suppressor
Richie-Van-GTi
Update, swapped wires around on the amp but the fault stayed on the same cylinders, probed the wires from ecu and both channels behave identical when cranking. Probed wires to the coil and same so looks like the known good coil has somehow packed up whilst being in the shelf in the dry for a few months
