Gerwyn
Gerwyn
Leslie green
Good idea if its going to narrow it would be at the bottom then door wont fit , hope you get it sorted and no doubt it's a big job
Gerwyn
Floor in , just weld it in now.
Gerwyn
When you have to improvise.
  • Haha 2
Leslie green
Was it tricky to get the floor in past the chassis rails ?
Gerwyn
Absolutely, had to jack up rear n/s take wheel off and support with axle stand right at the very back of car ,remove jack , cut away some of the rear floor where floor pan meets. Lots of other fettling and definitely not easy but achievable.
I'm-no-mechanic
Wow! That is a project!
I shall look forward to hopefully spotting it out and about in Cwmbran sometime!  You might spot my 205 out and about around Cwmbran from time to time, mines a 1998 1.4 Generation LHD, blue, but a deeper blue than your GTI. You should be able to see a pic on my profile.
All the best with the ongoing work, will be checking back to see your progress, great work!
Gerwyn
Might be some time before you see mine lol
Gerwyn
On 5/6/2022 at 10:18 PM, Gohn said:
who needs a 205 front end anyway
awesome, well done !
in case you dont already have all the replacement panels these places have some
https://www.steelpanels.co.uk/category/peugeot/205/
www.peugeot205.nl
https://www.serie04.com/gb/20599-body
https://alvadi.com/spare-parts/peugeot/205-741-1983/
Cheers bud. Many thanks for the links
Gerwyn
Let's start on replacement of the rear floor.... who needs big rims lol
Gerwyn
Gerwyn
Work in progress
Leslie green
This is impressive progress well done
Gohn
amazing , literally a from the ground up restoration
good work
Gerwyn
Thank you, surprising how much work involved. Hopefully have the floor in by next weekend after media blasting.
Gerwyn
New lower rear quarter weld in place on top of new sill. Good panel purchased off retro race and rally, had be cut to fit but quality part.
Leslie green
That looks a great job won't be long till its done at this rate
Gerwyn
Thanks, think it might be a while yet lol.
Costing me a fortune in the process and back bedroom filling up with boxes of new parts .
Gerwyn
Well the rear floor section has been fitted for roughly a month, offside sill fitted and lots of fabrication to the offside rear wheel arch. It's taking shape VERY slowly
Leslie green
Excellent progress looks like a solid car again now :D
Edited by Leslie green
Gerwyn
Looks a lot better without all the bracing.
Gerwyn
Gerwyn
Rear lower quarter welded into place
Gerwyn
Arch repair and sill
Leslie green
Nice job that's that side solid again now
