stumpyjag
306 dturbo
stumpyjag
Hi all. Can any one help me with my 306 dturbo which suddenly won’t start and I’m not that familiar with diesels. I have checked for power to glow plugs and fuel through the fuel filter and I can’t see any leaks on the injectors. I have cracked one of the fuel pipes on top of the injector and their doesn’t seem to be any fuel whilst cranking. Am I looking at the pump? Any advice would be greatly appreciated.
stumpyjag
Going to check stop valve next any other ideas welcome
Gohn
could you describe symptoms and if the engine has anything changed on it or is it standard XUD9TD
assuming its just konked out, it is most likely fuel feed
stop solenoid less likely
to check your fuel feed, set up a jerry can with diesel
line in to your fuel feed banjo, line out from the fuel return banjo
this is just bypassing your whole fuel feed system to check that your inj pump is ok
bleed it by getting fuel to your in banjo
crack each injector union nut and crank the battery until you get diesel to each union
once the diesel starts spotting out, tighten up each union
once you have at least three like that, tighten the last one also and crank the ignition
short burst, about 3 seconds
if you're unsure reply
good luck
gotta go, back shortly though
stumpyjag
Hi standard engine not messed with at all. Was absolutely fine until trying to start this morning. Got fuel upto and through the filter but not out to injectors. That’s why I thought stop solenoid?
stumpyjag
Really want to check stop solenoid but it’s under a steel cover. I have removed every bolt I can see and can’t get it off. Anyone know what I’m missing. Thanks.
Gohn
that sounds fair guess
could also be the filter (what a coincidence, mines just packed it in and brought my engine to a halt also)
if you've got a spare stop solenoid it is reasonably easy to check
install new one
loosen in banjo (M17 socket) and hand prime with the bulb til you get diesel without too much air spluttering out
then tighten back up banjo, connect wires to stop solenoid
crack union injector nuts and crank ignition
when diesel is coming thru union nuts ok tighten and crank ignition
still suspect the fuel feed is your culprit
see how you go anyway
Gohn
that cover is a part of a security type setup I think
bracket goes around the injection pump ?
the 306's got them,
hooks up to your ignition etc
never worked on one of those, sorry
The stop solenoid is controlled from the glow plug relay iirc, can you get access to the wire attached to it to check for 12v with the ignition on?
You could try putting 12v directly to the solenoid to see if it changes but they can fail & luckily aren't that expensive to replace, or at least weren't when i last ran an XUD.
As Andy says, the fuel filter on these is tiny & needs changing on every service iirc & they can become blocked to the point where the engine won't run.
g
stumpyjag
Just checked and I’ve got 12v going to the connector for the stop solenoid but just can’t get the steel cover off.
stumpyjag
Just looked on other forums and they seem to recommend angle grinding the cover off. Anyone else had to do this?  Is there any other way of checking the stop solenoid before I resort to that? Thanks.
Gohn
I saw a video of a guy trying to remove one of those once and it took him about two days
it looked messy
you could do a quick check as per graham
then recommend check fuel feed
filter or hoses somewhere in there'll be the problem
stumpyjag
I have definitely got fuel through the filter and into the pump via the bleed screw. If I pump the hand pump but nothing out to the injectors. Everything worked fine until this morning when it wouldn’t start. Does that eliminate fuel pipes and filter?Thanks for your help.
SRDT
If the stop solenoid is hard to remove then it must be the coded one. If it was easy you could steal the car in a few minutes by fitting the older regular solenoid.
Gohn
no, not really
its not a total blockage or good
The injection pump is at the end of a line of hoses, filters, joins etc
It needs good clean diesel flow all the way thru
Almost always, the object is to ensure your fuel feed is sealed, the pump will do the rest
the pump is pulling diesel thru lines all the way from the tank
if there's a leak, it will pull air into the lines instead, fouling the diesel flow
You can get a total blockage like if the Stop Slnd ceases working
but usually its just leaks, allowing air into the fuel feed thru one or more leak points
The pump stuggles on for a bit but as it gets more and more air in, the air getting into the fuel feed stops the pump
so you may still be able to primer bulb diesel thru to your IN banjo, but its likely that there's air in the lines being pushed thru also,
but you cant see thru your hoses
also, diesel to the IN banjo does not mean the injection pump is primed (full of diesel, no air)
the high pressure chamber/area of the pump will have air in it
it will self prime once it has access to clean AIR FREE diesel
pushing out the air thru the injector unions you have cracked, once you crank the ignition
 a few sections of clear hose 8mm can isolate where the bubbles are coming in
few days ago, my OE filter unit packed it in (its old, but they are known for it)
car conks out
towed home
set up full jerry can of diesel at the front of car
2 lengths of 1.5m clear hose (only good for using briefly, as its not fuel rated)
cut one hose in half and insert a primer bulb. this is feed IN line
attach to IN banjo, put other end in diesel can, crack in banjo nut, pump diesel up to banjo, retighten nut when the diesel has chased all the air out of hose
attach other clear hose to return banjo and stick other end of hose in diesel can
crack injector union nuts
crank ignition
as pump self primes, then pushes deisel to each injector it expels air, each injector starts spitting diesel, retighten union nuts until all 4 tight
crank ignition again, engine fires
any pics of the security code rig thats preventing your new stop slnd test ?
Cut the steel cover off, undo the 4 wire stop solenoid and bin it, fit a 1 wire type, then rig up an ignition live to it.
stumpyjag
Thanks for the reply. Just tried putting fuel straight to the pump as you explained and I can get nothing out of the pump. Does this only leave me with stop solenoid?  Thanks
stumpyjag
Big thanks to everyone for the advice. Cut out armour and removed solenoid. Seemed to be dead. Removed plunger and put back in. Bled system and she fired up. Off to motorfactors to buy single wire version. Thanks again.
