boldy205
GTi6 ECU mounting
boldy205
Hi all,
I have to date been using a 306 battery/ecu box on my GTi6 converted 205.
I'm now putting the battery in the boot. Therefore I'd like to know what other people have done to mount the standard ECU in the standard position.
I've had a good Google,  to no avail.
Thanks!
Matt
boldy205
Just re read my post. By standard ECU position,  I mean when it would be in the battery box.
Cheers!
allanallen
Morning Matt, I chopped the ecu box off the battery box and the mounted it on top of the gearbox mount up against the strut tower.
from memory I put a few riv nuts in the bracket and then bolted the box straight down to it with some big spreader washers on the inside of the box.
haven’t got a picture to hand but if you find my 309 build thread there should be a picture in there.
boldy205
Hi Allan,
I had a look at your 309 build, got a bit carried away in it all and totally  forgot to look for the battery box! Haha!
I'm thinking this may be the way. However I'm a bit against chopping up a good battery box.
Think I'll take what you said and maybe have an aluminium ecu box made up, modeled on the modified/cut up 306 battery box .
allanallen
Ha! Are 306 battery boxes a rarity nowadays?! :lol: Get chopping!
boxes arent but the lids are :lol:
boldy205
Definitely.  I've got a box and lid. Don't really want to waste a good one if I can help it.
Do it properly. Mount the ecu in the OEM position and remake the loom. Otherwise, it will always look like a bodge.
boldy205
Good point Peter. Maybe over the winter when I have more time .
pretty sure it is winter, certainly below freezing yesterday :wacko:
boldy205
Indeed it is......Next winter!!
Ron_Jaegers
If you (very) carefully remove the moulded (resin filled) bend on the ECU connector you gain about 10 cm of loom. For my car this was enough to get the ECU inside without having to re-do the entire loom. But mine is LHD and stripped out, so placement for me was completely free. Maybe something to consider.
boldy205
10 cm? Does some wiring 'pull out' of somewhere?
I'm wary of messing with old wiring too much,  especially on a bend like that.
I will take a look though.
Thanks for the idea.
Ron_Jaegers
10 cm is my estimate for useable extra length. It does not ‘pull out’, the extra useable length is merely from straightening those two bends.
Since an image is way more clear. This is were I end up on my car.
boldy205
Thats a fair bit of usable length.  Thanks for the pic.
