Thehud
Eibach front Springs
Thehud
Hi,
I’d like to keep my car as original as possible but there’s a few small mods I’d like to carry out, one of which a more lowered look.
can I just go ahead and add Eibach -30mm on the front and leave the rear as-is, or should i make an adjustment to the rear too?
cheers
jord294
Adjust rear to suit aswell. Budget in rebuild of the axle if you have no history of beam being apart in a while. If you're local to North Wales, then axle lowering is a service I can offer if you are not confident yourself
  • Thanks 1
Connor
Hi,
On my GT model I have the 30mm lowering springs at the front and a standard height at the rear with a refurbished rear axle and it looks good. I think the cars were always a little bit lower at the rear anyway so to my eye it balances it out a bit.
  • Thanks 1
Thehud
Cheers. Yes I’ve seen people just doing the front and that’s what I’m thinking. Thanks pal.
Thehud
Cheers, I’m thinking just doing the front. I’ve been given a recommendation for someone else in North Wales that does Axles fit if / when I need it.
jord294
Who would that be?
Thehud
23 hours ago, jord294 said:
Who would that be?
I’ve just realised I think it’s actually you after checking your profile just now (haha!) I thought your name was Jordan from your display name.
My good pal John from Chester said you’ll be the only person I should need, you’ve done work on his grey GTI6.
jord294
Small world
Thehud
23 minutes ago, jord294 said:
Small world
Yeah I think his brother Ben was interested in your PUG estate recently.
I’ll get in touch Early 2021 regarding lowering if okay? Cheers, Steve
Thehud
2022(!)
Thehud
@jord294 tried to message you directly on here, but doesn’t seem to let me.
can you inbox me please? Cheers
jord294
Replied via pm
