Eugene wilson
reverse light bypass
Eugene wilson
hello ive started on the wiring gremlins on my 1990 1.9 gti,im going to remove the reverse sensor connector put  2 female spade connector on fit that and see if thats faulty ive put tester on it and its dead,i think the pink wire is the sender if thats the right phrase and the browns the live feed .id like to know where to send the permanaent brown live feed to ,i fought the small fuse box under the slam panel,has anybody done this bypass before,if so could you give me some advise,ive fitted a new sensor already,cheers all.
