pugfrank
Fixing clips & bolts bumpers and trims?
pugfrank
Hi all,
Im due to have a go at removing bumpers front and rear and and side trims on my 1.6 gti.
Got a couple of questions as have never done this before,  I have done a few searches and understand the main fixing locations of the bumpers.  They are probably not going to undo so cutting and grinding is probably on the horizon, so my question is where is the best place to purchase replacements fixings ? is a kit best? or can you buy everything individual?  Found this kit on ebay any good?
https://www.ebay.co.uk/itm/NEW-GENUINE-Peugeot-205-GTi-Bumper-Fitting-Kit-Fixings-Clips-Bumper-Bolts-/392078756422?var=0&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338268676&toolid=10044&customid=Cj0KCQjwl_SHBhCQARIsAFIFRVWBB9P3roZrASJA0vrj6RtsIXbeq_2s869b49ZEGPF8vZMdmBcn-V4aAvrIEALw_wcB
Also something Im not clear on is how and when you remove the red trims from the bumpers? do they come off before you remove grey bumpers from the car? or after and if so how? Is is possible to remove red trims and not bend and buckle them?  Sorry of this question has been asked before, but could not find an answer when i searched the forum, might have been using the wrong word phrases.
I certainly would not be buying that kit, the very same seller used to do them at £24, all they do is buy from a Peugeot dealer in bulk and sell on at a huge profit.
BakerBM do a bumper mounting Kit as well as some of the individual parts, the plastic clips will likely be reusable.
it is possible to unclip the trim pieces, get a set of trim removal tools, Halfords, Amazon, ebay etc can provide a wide variety.
pugfrank
Thanks Welshpug, Do you know how I get hold of all the part numbers for all the clips and fixings so I can source individually?
pugfrank
Sorry Welshpug, so i can remove the bumpers and side bumpers with red trims still in place?
Gohn
no, the red (or chrome in other models) trims need to be carefully lifted up/out at each end.
under these is the bolt end that slots into the bumper. the other end of this inside the wheel arch is a nut
undo nut take out bolt to each side,
also two to front of bumper, take out headlights or grill panels to access nuts in behind
they are the 4 main fixing bolts all under the trim strip
the trim removal tool mei recommends is good but you can use a flathead just be careful and gentle
you shouldn't need to do any grinding, even with the corrosion problems there
and if you're careful getting it off all the plastic bits will be ok to reuse
farmer
Mei you are behind the times a little !!
Those kits are near £41 each now RRP
Hardly a huge markup times you minus fees
pugfrank
Thank you
pugfrank
Job done :rolleyes:
Thank you
pugfrank
Snapped this bolt yesterday, what's the best fix?  Thread is captive, you cant get to the other side, I don't think.
Edited by pugfrank
wrong image
It is welded onto the inner end of the front bumper "iron". Once the bumper is off pull the iron out of the chassis leg and you will see. I have repaired plenty of them by grinding the original bolt off turning the head down on another bolt and welding it back on.
DamirGTI
Insides of the thread is chassis leg , thus not accessible .
If you can weld , weld an nut on to the bolt remains and wait till cools down .. then unscrew , might need few times try but by far it's most effective way .
Or usual , drill it and use broken bolt extractors (be careful while working with extractor tools , as it can snap inside and it's hardened steel very hard near impossible to drill afterwards ..)
If i where you , i'd just remove that bumper support bar and "say nobody about it" ... forget about it ... don't have them on my 205's for years of use .
D
DamirGTI
Right ! spot on Tom i completely forgotten about it ... the black iron bumper bars that slide inside the chassis rails .
Yes , easy fix by grinding off old broken bolt remains and welding on new ones .
D
(EDIT : ignore my post above !)
Edited by DamirGTI
pugfrank
Thanks guys, all became clear :D
pugfrank
I came to removing the last couple of red trims, which are the ones on the front wings (120mm long)  are these fixed differently to all the other trims? no amount of prising from the face with a small pallet knife was going to get them off! started to bend one  :blink: so decided to stop and ask the question on  here.
pugfrank
Should I be using a tool more like this one ? that leavers from both sides of the fastening?
Gohn
this is a dont know ,
I've only taken off GTI trims once (they were bodged onto a base model body by a prev owner)
not sure if his fastening system was exactly factory either
cant remember but maybe this small section was screwed on or something ??
during removal I was only trying to ensure the body didn't copy any more of a beating
sounds like your current situation
I'd go check the trims but I gave em away soon after
if you use the tool above dont forget to put a cloth or bit of leather under the heal first, it'll save your paint
good luck
Gohn
hang on a second
maybe this pic will help :
or maybe not, geez i dunno
looks like the arch fixings are pozi head screws and the two that you're stuck on are maybe press in body clips ??
pugfrank
9 minutes ago, Gohn said:
hang on a second
Yes the ones Im struggling with "C" seem to be press in body clips, thank you Gohn.
pugfrank
Sorted, I removed the whole wheel arch trim, which took the red trim with it. No way was the red trim going t come of with out damaging it.  Removing the whole wheel arch trim was the trick.
