Dimi
Rear wiper plastic panel removal
Dimi
1.9 1993 gti. I tried looking everywhere also using search on this forum, and cannot figure out how to remove the plastic cover over the rear wiper motor. I can see some white clips in the corners and I do not want to pry further and break some unobtainium stuff.
My rear wiper motor is very noisy and I wanted to open all up and clean/grease the arms and all. See photo of the cover.
Let me know the way you have taken the cover off, please.
AlexRS2782
Last year when i removed mine i just eased it off all round by using a panel removal tool and then carefully pulled it down towards me.  Do it carefully and the mounting brackets in the panel itself shouldn't break.
A couple of the white clips might crack / split due to age when removing, but they can be replaced as they're just plastic retaining plugs.
Edit - example from UK ebay below (Pug code is 6996.45) - https://www.ebay.co.uk/itm/190705490545
Dimi
Much appreciated, Alex!
Now I got the courage to give it a go with a proper trim plastic removal/pry tool.
Will follow up with photos over the weekend.
Cheers!
Dimi
Two photos for reference of the clips holding the rear wiper motor cover to the tailgate. I did not brake anything, but the pulling was scary. Now to figure out why that motor/drive grinds so badly and looks like new...
