camarda
205 SI
camarda
Hey,
What are the main differences with a 205 SI and GTI other than the engine and brakes. I found one for sale with 306 brakes installed and was wondering how hard an engine/ engine and transmission swap would be. Is everything else handling wise etc. on the car the same?
Gohn
it helps if you indicate what you're looking at
year model, auto/manual etc
the 205Si came out from '90 on, whilst the earlier version of the GTi was sold here from '87 I think?
so you'd need to be getting GTi bits from similar later model cars for any conversion
you could draw up a list of things for yourself
then go thru and compare part numbers on here to double check:
https://catalogs.ssg.asia/peugeot/?lang=en
for engine
assuming you are referring to the GTi 1.9 litre (XU9)
I think the Si has the same XU5 engine as the GTi 1.6 litre (which we never got in aust)
its a good engine and you dont really need to get the more powerful XU9
engine mounts same
you'll need to get all the engine ancillaries, air ducting, expansion tank, hoses, etc as many are different
the Si has a good radiator, think same as GTi
exhaust on the GTi is more expensive but no need to change from Si
peddles same
the gearbox
both same BE3/5 but the Si also got a nice little ZF auto 4 speed (thought I'd hate it until I drove one, its very cool)
you can put the auto box on the XU9 engine no problem
I think the GTi ratios are very similar except for maybe 4th and 5th where they're more racier so going along highway its doing a few hundred more rpm
recommended: helical/torsion limited slip diff
brakes
Gti has front ventilated disk and rear disks, Si has solid disks front and drums for rear
Si rear drums I quite like, but the Si front brakes are kind of s*it, its such a light car they should have no problem pulling it up on the spot, but seem to labour
probly why the one you're lookin at has been uprated
with GTi disks you'll need Gti calipers
swapping to GTi front end will mean you probably need to move/fabricate the Si front brake line brackets as they foul the droplinks
they're located in a diff spot on the GTi
apparently some Si conversions can get away with where the brackets are but I'd plan for some welding..
I did a topic on it but cant remember the name, all pics and info is on it
rear end
torsion bars Si 18.9mm, GTi same I think ?
same shocks, keep the originals if you have them they're great
Anti roll bar ARB may be thicker on GTi,
pretty sure the rear beam is same also
front end
you'll need a GTi subframe, wishbones, GTi ARB, GTi struts and shocks
and GTi hub carriers (they have larger wheel bearings), same drive flange (hubs), and different vent disks
see the section in technical
so you could chop and change by removing the drive flanges off the hub carriers but they'll just be sold as one and called GTi hubs
and GTi has different driveshafts
Si interior is direct swap, just less contronting red everywhere
front and rear GTi bumpers are slightly wider, front Gti quarter panels are wider to make it look a bit faster
think the rear Gti quarters are wider also
and someone said the GTi bonnet is different, but I think its the same ?
..not owned a GTi so there could be a few mistakes
Most people on here wouldn't be familiar with an Si, as they were only available in Australia from memory. The engine whilst a 1.6L, is similar but not the same as the GTi. It's called an XU5JM, having single point injection, less compression and a smaller camshaft. The manual gearbox ratios are quite wide with a long final drive. So fairly relaxed cruising. The rear beam is smaller in overall diameter, so you can't fit huge ARB's in. Not that's an issue unless you race it.
You can fit larger brakes on the Si front hubs easily. They call them "base model" in the UK and take the same driveshafts as early 1.9L GTi's in Australia.
The body panels are different, because they don't have flares.
Gohn has covered just about everything else other than the power steering. The Si rack is highly sort after in Australia as it's the fastest ratio available (2.7:1), other than the early Xsara rack (2.4:1).
Edited by petert
