Spesh
J4RS head skim + gasket thickness
Spesh
My head is currently in the machine shop after a head gasket failure, it didn't look in bad shape but it had just marked the head between the bore and a water jacket so its going to need a skim of some sort.  The head was unskimmed (measured 137mm and the 2 bits of rough casting were still there).
My question is at what point does a thicker head gasket become neccasary?  The engine is standard in all aspects.
Should I need to go down the thicker gasket route is there a way that avoids the composite gasket from pug?
by the tech data any time you skim you should use a repair gasket.  nothing wrong with a fibre gasket really, thats what every alloy xu uses.
SweetBadger
If you want an MLS gasket then Cometic do various thickness, and will also do a custom thickness on special order.
around £100 for the gasket from memory.
