K20205
Windscreen washer not working
K20205
My 205s washer just stopped working randomly, i checked voltage at the plug and its getting nothing, and when i pull back the stalk the wipers wont work too, just the up position and the two lower ones work one for low speed and other for high,
i have two stalks that ive tried and none of them work when pulled back,
what can be the problem? Also both stalks look different? Why?
the car is a base model 1.1 xl
Simes
Stalks fail.
cgeck connection at pump and the really.
base model doesn’t have rear wash wipe nor intermittent for front.
I managed to buy a brand new replacement for  GTI only to find intermittent didn’t exist on it. Mid old but after years of dealing with no squirt for MOT it gets me through!
K20205
I took apart both stalks and cleaned them,
so there is no option to pull stalk and a spray for basemodels?
im getting no voltage to the wire at the pump? Why is that?
i checked the wiring diagram and on the stalk connector there is a wire labeled 87 and that one doesnt seem to be on the diagram, also which wire should have voltage when the stalk is twisted to spray? Is it 102?
K20205
I sorted it, rookie mistake, the pump was faulty. And was trying to check voltage with just the key in the barrel.
