K20205
Rear beam no travel
K20205
I just lowered the rear of my 205,
the rear end is solid now there is no travel, what can be the cause of this?
when i jack it up the wheels travel up but when its on the floor the rear wont travel at all,
allanallen
Too low at a guess, sat on bump stops and/or the damper is fully compressed.
jord294
Lowered too much.
K20205
17 minutes ago, jord294 said:
Lowered too much.
Would it cause any issues?
very little grip
allanallen
If it didn’t cause issues cars wouldn’t have suspension! :lol:
  • Haha 1
probably handles like a gokart.
i.e s*ite.
  • Haha 1
Telf
I'm always puzzled by the requirement to mess with ride height. The design engineers must have been onto something when they designed the GTI. Handles great but still it gets messed with. I just don't get it . Not just with the 205 but most cars.
barneys66
Most cars look better lowered :D
Telf
Just now, barneys66 said:
look
Well thats OK then. My car looks nice if I don't drive it :D
  • Haha 1
K20205
The height was already played around with, one side was lower than the other,
i tried to correct this but i must have lowered it too much now,
Next week im just going raise it and hope its all level.
does the arb need to come out or just remove the 13mm bolt and that it?
The ARB doesn't need to come out, but probably easiest to take it out as you've no idea if it's been put together with the two end plates aligned or not, and if the ARB is pre-loaded it'll mess with ride height and handling.
By far the easiest way to set the beam height and make sure it's the same on both sides is to use a dummy shock - which could be as simple as a length of wood with two holes in a set distance apart.
Are you still running standard 19mm 205 GTi torsion bars?  If so, 322mm between holes is standard height, and somewhere in the region of 315-310mm works for lowered cars, depending how long you want it (shorter distance equals lower).  Uprated/thicker torsion bars need to be set at a shorter distance for a given ride height.
K20205
The rear is totally standard as far as im aware.
ill just make a dummy damper and place that in there and adjust accordingly.
Telf
Thats how I set mine
K20205
Ive been to the garage this week and i have managed to raise the rear but there is still no travel when the car is on its own weight,
does the rear arb need to be pre loaded when the rear is in the air or should it be set when all four wheels are on the ground,?
when lifting the rear there is travel going up but when its down it really stiff? I also had a hard time fitting on of the arb plates on as one side didnt line up?
its got koni rear adjustable dampers would that have anything to do with it being so stiff?
i uploaded a video of me jacking the rear up and have a look at the rear travel.
https://streamable.com/18d8wy
there should not be any preload in the arb, if the bolt will not go in the hole easily then the height of the arms is not equal.
koni dampers are decent, can be a little stiff if adjusted to extremes.
K20205
I just read on one of the topics about why it wont line up and i found out to be that the arb bracket has a groove on one side and on my one someone had played around with them, i redone it by setting the groove facing the 8mm bole hole location and refitted; it now lined up but its still the same,
can there be too much load on the torsion bars? What if i remove them and refit it? Would it release the tension?
the back end has been played around with too much and im starting to doubt that it can ever be back to normal again.
Edited by K20205
unless its bent it can always go back to normal, you fit the arb when the arms are under no load after fitting the torsion bars, so should be even either side if assembled competently.
K20205
Tomorow ill just take the two 13mm bolts on the arb brackets off and the remove the torsion bars one at a time and re install and hope it fixes it.
jord294
K20205
I'm happy to put this right for you, if can wait till lockdown lifted
K20205
22 hours ago, jord294 said:
K20205
Thank you mate, i think i found why, its the dampers, they are too too stiff, i removed both of them and there is travel without any dampers inplace, i even had a hard time pushing down the dampers down by hand..
can i just replace them With oem spec ones or  should i just keep them?
they are koni series 30 dampers
dampers will not be the cause, they have no effect on the ride height.
K20205
The height is fine, there is no suspension travel, the dampers are just too stiff.
i ordered a set of oem ones let me see how it is with them
jord294
Are the koni adjustable? If so, perhaps wound up to maximum setting??
K20205
Yes they are adjustable, its got only 3 adjustment point and even on the softest setting its hard.
