Moby
Radiator Warning light
Moby
Hi. There’s a red warning light on my 205 dash , looks like a radiator. It comes on for a few days then Goes off for a few days. I’ve done the obvious like checking water etc but that’s ok. Could it be a pressure fault or something. Would draining it all and then re filling with new antifreeze and water top up help ?
many advice would help.
thanks in advance
That's the low coolant level warning light, assuming it's the one below the battery/charge light in the centre of the instrument panel?
If the coolant level is definitely OK, then it's possibly a dodgy/failing sensor, possibly shorting wiring or, in the case of the Ph2 black expansion tanks, the sensor can be falsely triggered by HT interference.
Simes
If it’s the phase one sensor take it out and clean it up. Shake it around and watch rusty crap come out.
Moby
Yes Anthony, it’s that light. It’s a phase 1.5. I’ll try checking the sensor and see wot happens
cheers.
