Danez
Any tips for replacing a heater matrix? (306)
Danez
1 hour ago, welshpug said:
doesnt look like coolant, does the car have a sunroof?
yeah surely coolant wouldn't separate from water like that? And yeah I do, do you think the drain plugs in that could be to blame?
1 hour ago, Anthony said:
Dip your finger in it and taste it - you'll soon know whether there's antifreeze or not.
I can't remember if 306's are the same, but I know on 205's if you don't fit the scuttle panel cover properly you get water in the footwell when it rains, so worth double checking that if it doesn't taste sweet.
Well annoyingly I've not cleaned the carpet since coolant leaked from before I changed the matrix so it probably will taste of coolant anyway.
I'll check the scuttle panel out as well cheers
there is also a cover for the heater inlet from memory with the 306.
could be blocked drain tubes in the sunroof, or damaged door membranes, shrunk rear quarter seals.
