wladimir031
GTi6 2.3 stroker
wladimir031
My new engine project..
Head:
Ported and polished RS head with catcams '109 (274*/267*)
Bottom end:
Dw12 crank (96mm)
Honda K24 87mm pistons (k24a3) PH 30mm
PEC forged rods (22mm pin) (for gti6 turbo aplication)
Edited by wladimir031
wladimir031
Some work ... Rods hit the block wall on crank spin.. Some grinding to complete
wladimir031
In the end piston skimed by 1mm because piston comp. height is 30mm
235-48-158-30= -1mm
Looking good! What about valve to piston clearance? How will you solve that?
wladimir031
Its ok
Inlet about 4-5mm clearance
Ex. Cca 3mm
Iil dig depeer more anyway because piston dish volume, now is only 3-4cc, i must have about 10-11cc for cca 11.8:1 CR
What width are the big ends of the rods?
wladimir031
24mm like stock gti6 rod
I’m looking for rod/piston combo for my turbo build. There are plenty of dish options in the K20/24 range. Facing 1mm off could be the answer.
opticaltrigger
Great project,
Out of interest, how long are the rods and what does the rod ratio come out at when you do this conversion?
All the best,
O.T.
B1ack_Mi16
He states 158mm  (235-48-158-30= -1mm)
Rod/Stroke 1.65
opticaltrigger
Thanks Kristian, I hadn't seen that he had already stated it above.
But yea'h, 1.65, Nice.....
All the best,
O.T.
interesting, same length rod as mine though I'm on a 92mm crank.
Spesh
How did it go with increasing the dish on the pistons?
wladimir031
Pocketing the valve reliefs ... dish is about 8cc
Steven Wylie
I know this is an older post just wondering on how much deeper you went when pocketing the valve reliefs am meaning to run catcams 109
dcc
You need to do a dry build I'd say. But for the cost of some decent pistons is it worth the hassle?
Steven Wylie
Well had the time this morning to look into pistons and can get a custom set made for 600 which I thought wasn’t to bad. Was just because I had a set of standard k24 pistons sitting I thought about using them
Regardless of std pistons or not, when you do custom builds and/or big cams, you have to measure valve to piston clearance accurately and mill pockets accordingly.
Steven Wylie
Ok that’s great thanks new to this na builds with big cams as use to evos and there’s not many folk in my area with knowledge of the xu10j4rs still undecided on cams as with it being 2.3 stroke probably won’t be able to rev as high compared to the standard 2.0
IRISH_MI16
If the appropriate valve train is in place it will. A 96mm crank machined and balanced ends up 1kg to 1.5kg lighter than a standard gti6 crank aswell.
300 degree cams should be good with the right valve reliefs
