ob2s
Removing Valeo Headlight Lens
ob2s
has anyone successfully removed the glass lens from an OE Valeo headlight ? I had a deer remove mine, but reinstallation is not possible :-( I would like to make some modifications to internals of the headlights. Removing glass chards from the gasket was a challenge, so I am thinking maybe a heat gun would help ?
Gavin Waddell
I had a pair of driving lights I wanted to paint the lenses yellow, I stuck them in the oven ( whilst no one was home) at 100c, It heats up everything evenly. I kept checking them every 5 min to make sure nothing melted and once they where nice and hot the lense pulled off no problemo.
gavin
  • Thanks 1
Ozymandis
Gavin, were they the earlier Valeo type, part metal part plastic type or the later Valeo ones all plastic?
Gavin Waddell
I didn’t do it to a headlight but to a driving light. The thing is to not heat them up to much so the plastic doesn’t melt but it softens up the sealent. I think there our a few videos on you tube.
davemar
I put mine in the oven at around 130 degrees (try different temps) which was enough to soften the sealant. Fitting the lens back on was similar - put both lens and body in the oven, then press them together when the sealant is sticky. Obviously wear some thick gloves!
ScoobyJawa
I put my valeo in the oven at 100-110 for about 20min then they just pry apart. I then cleaned/scraped off all the crappy old sealant and put them back together with tiger seal .
