Kasey23
Fuel Pressure Reg
Kasey23
Hey all, I’m trying to find a fuel pressure regulator for an 89 1.6 only one I can find is from Australia and quite expensive. Peugeot have discontinued this part.
Any ideas where I might be able to find this part? Any help would be very much appreciated. Thanks, Paul
farmer
Some on Ebay
1563 99 use that search against
Kasey23
Thanks, I couldn’t find any others but I’ll check this out.
DamirGTI
Try also : Bosch 0 280 160 226
Old 0 280 160 258 is discounted for quite a while , replacement for it now is : 0 280 160 249 (and it's 2x more expensive than the old one !)
Lots of others Bosch capsule reg. various different part numbers fits and works as well , from old Volvo's , Alfa , BMW etc. .. just look for the same shape with mountings to the fuel rail and 3 Bar. rating .
D
Kasey23
Thanks Damir. Appreciate the help.
bacardincoke
Went through looking for one a while back...
Genuine Bosch 0280 160 258 are very thin on the ground and generally expensive if you do find one.... Later ones less scarce, but just as costly.
Unless you're in a rush to replace and it must be a Bosch, keep looking... I eventually found one in Turkey of all places, old BMW stock (seems the exact same regulator / fitting bracket was used in E30's) for around £75 posted.
Still a lot but then latter day Lucas versions for example aren't that significantly cheaper and like I said in the other post, that's maybe for a reason?
Perhaps someone running a Lucas or similar can comment, there were no replies the last time and it would still be useful to hear.
This one's in Italy and as expensive as I've seen but at least obtainable if money's no object.
https://www.ebay.fr/itm/BOSCH-0280160258-PEUGEOT-205-Mk2-Gti-1-9-SENSORE-PRESSIONE-CARBURANTE/153788239335?hash=item23ce7e4de7:g:JYMAAOSw4DVeFGMN
DamirGTI
I'd reconsider an second hand/used one too ... if new is not a "must" .
As they're pretty reliable , rarely go bad , used one will certainly also work .
D
soundguy
This is the one I narrowed down as a compatible replacement, but I haven't bought/fitted it (£77):
https://www.ebay.co.uk/itm/PIERBURG-Fuel-Pressure-Control-Valve-for-BMW-3-Series-7-21197-60-0-Mister-Auto/311490278261
DamirGTI
"Pierburg" should be good .. similar if not the same quality wise as the Bosch one .
D
bacardincoke
Found a later, but new Bosch 0280160249 in the US, seller posts internationally however you'll have to factor in the the eBay pre-paid customs taxes at check out... off the cuff all in will be a ball park £115'ish.
https://www.ebay.co.uk/itm/OEM-BMW-M20-325I-E23-E24-E28-E30-E34-Fuel-Pressure-Regulator-Bosch-0280160249/133484585042
Kasey23
Thanks everyone, I now have one ordered and on route. Appreciate all the help.
