SootySport
Gear linkage
SootySport
How do you seperate the linkage ball joints? need to have the box out to change clutch.
Easiest way is a suitable size open ended spanner and lever them off.
SootySport
So they just pop off with no secret catches, screws or springs?
Thijs_Rallye
Yes, as long as the hole is sorta above the ball. Don't force them off if they are slanted to one side. 16mm spanner works fine.
SootySport
Ok boys, I'll give that a try, thanks.
Some aftermarket upgraded rods have locking pins that need to come out first.
