Aidan205
Both reverse AND fog coming on?!
Aidan205
Hi, new (old) member after some help
Just getting my GTi MOT ready, it hasnt been on the road 15 years. Thought i was there, but have just done a full lights check.
It's a PH2 so has fog and reverse in bumper
Initially, when i put the car into reverse, the fog light also came on. So i pressed the fog switch on, and both remained on...
I then went under the rear bumper to check connections, seem to be correct (not wrong way round etc). Now ive connected everything back up and the fog has stopped working...
So now, when i put the car in reverse, the reverse light comes on. BUT, when i put the fog on, the reverse light also comes on! The fog itself doesnt work at all!
Argh!!!! Any pointers appreciated, electrics are my weak point
(For the record, fog fuse and bulb both work, ive checked them)
Have i potentially messed up the wiring further by fiddling i.e. car in reverse, fog switch on, remove connections, fog switch off, connections back on, remove from reverse (those sort of cycles?)
check the connections in the rear of the left hand light cluster, both are fed from there iirc
Aidan205
Thanks very much, i took the l/h cluster off today and sure enough both the blue and red wires (reverse / fog) had been crimped together. Absolutely no idea who or why they would have done this but i've cut and re-joined them separately.
I feel a bit silly having asked the initial question now, as i cant believe it was something so simple (and stupid!), but thought there might be some well known issue that caused the problem.
nice to find the smoking gun and have a relatively easy fix!
