fedenl
205 CTI wobbling start
fedenl
Hello everyone, i have a problem with my 205 CTI (Xu5ja 1.6 originally) with 1.9 GTI 8v ITBS engine. It has a 405 Mi16 flywheel and 205 Diesel axles.
It starts wobbling when a put on gear and start moving releasing the clutch slowly. I have to accelerate the car to not getting this effect.
I made a video to show you guys the problem, does anybody knows by watching it what could it be?
Thanks!!!
Worn out engine mounts? Lower one most likely.
The video is mirrored which is very confusing :lol:
fedenl
Haha sorry, its the long axle side.
Could it be the lower engine mounting?
Does anybody had this problem?
Thanks!!
Thanks!!
Yes 100% it could be the lower mounting.
I have seen it cause that symptom more than once, just not from that angle...!
The gearstick will flap about inside the car too.
If it gets too bad the oil filter can even hit the radiator.
fedenl
Thanks Jack, I'll give it a try and tell you if it worked.
