Adamstanford
Ph2 1991 intermittent wipers not working
Adamstanford
This was an intermittent problem (geddit?) But is now a constant problem.
Normal wipers, fast wipers and spray all work. Intermittent doesn't... Is there a relay that controls this or is the stalk faulty?
1991 1.6 GTi.
dcc
I think I had this issue about 5 or 6 years ago, and I am sure I fixed it with a new relay. I fitted a relay from a mk3 golf which let you teach the car what you wanted your intermittent wiper speed to be.
I *think* its a relay 99 from a vw. I'll have to go and have a look.
and you can program them with this
1. Click the wiper lever on. (Intermittent)
2. Click it back off soon.
3. Wait how long you want the delay.
4. After that, click the wiper on again. (Program it)
dcc
ooo a quick google found this website with the below info
357 955 531 (original VW 99 relay)
or 1HM 955 531A or B.
The Bosch # is 0-986-335-058.
The number stamped onto the end is "99".
vw relay part number 357 955 531 (This has maybe been superseded with 3BO 955 531)
357 955 531A, 1HM 955531, and 1HM 955531C are the NON-programmable intermittent wiper relays.
1990 Volkswagen Corrado
1991 Volkswagen Corrado
1992 Volkswagen Corrado SLC V6
1993 Volkswagen Corrado SLC V6
1994 Volkswagen Corrado SLC V6
1995 Volkswagen Golf Cabrio III ABA
1996 Volkswagen Golf Cabrio III ABA
1997 Volkswagen Golf Cabrio III ABA
1993 Volkswagen Golf III GL 4 CYL
1994 Volkswagen Golf III GL 4 CYL
1995 Volkswagen Golf III GL 4 CYL
1996 Volkswagen Golf III GL 4 CYL
1993 Volkswagen Golf III GTI 4 CYL
1994 Volkswagen Golf III GTI 4 CYL
1995 Volkswagen Golf III GTI 4 CYL
1996 Volkswagen Golf III GTI 4 CYL
1993 Volkswagen Jetta III GL 4 CYL
1994 Volkswagen Jetta III GL 4 CYL
1995 Volkswagen Jetta III GL 4 CYL
1996 Volkswagen Jetta III GL 4 CYL
1993 Volkswagen Jetta III GLS 4 CYL
1994 Volkswagen Jetta III GLS 4 CYL
1995 Volkswagen Jetta III GLS 4 CYL
1996 Volkswagen Jetta III GLS 4 CYL
1990 Volkswagen Passat 16V
1991 Volkswagen Passat 16V
1992 Volkswagen Passat 16V
1993 Volkswagen Passat 16V
1995 Volkswagen Passat GL 4 CYL
1996 Volkswagen Passat GL 4 CYL
1997 Volkswagen Passat GL 4 CYL
1992 Volkswagen Passat V6 AAA
1993 Volkswagen Passat V6 AAA
1994 Volkswagen Passat V6 AAA
1995 Volkswagen Passat V6 AAA
1996 Volkswagen Passat V6 AAA
1997 Volkswagen Passat V6 AAA
Adamstanford
Wow thank you that will be a cool little feature to add. I'll get on finding one soon! Just plugs in to the fuse board in the glove box?
Adamstanford
The 6 pin one? Big 99. On the top?
I've had a VW relay in mine for years, it works very well.
Yes it has '99' printed on it in a large font, you can't miss it.
Adamstanford
Thank you I have ordered one!
This shows one fitted to a 205 fusebox:
(it's not my photo, I think that is a LHD car but the fusebox is the same)
Adamstanford
Perfect! I shall report back when it arrives!
check the condition of the terminals on the plug in the scuttle
Adamstanford
Theyve sent me "191 955 531"
Works as a relay. Not programmable.
