estland
Oxygen sensor problem
estland
Hello,
My car has started showing check engine light while driving. The fault code is 51 which indicates an oxygen sensor.
When I tested the sensor the output voltage was from 0.2 to 0.8 volts. When I created a vacuum leak the voltage started slowly dropping to 0.25 volts.
Can the sensor still be faulty or can there be some other fault?
I take it's a  Motronic DKZ? If so yes, they're very fussy about oxygen sensors.
estland
Thanks for the reply :). Yes, it's a xu9jaz engine.
 I cleared the fault code by disconnecting the battery lead and for one day I haven't had a warning light.
 I'm suspecting a "lazy" sensor as it's near 30 years old now.
