gtiburge 0 Posted May 19, 2020 I no this has sort of been covered but all the searching I can’t find a definitive answer I have just put a radio in my 1990 Xs and there is no switched live , I have tested each pub on the peugeot plug and the cig lighter as it’s close but nothing is switched so where is the easiest place to pic a switched live from so the radio works correctly Thanks Olly Share this post Link to post Share on other sites
welshpug 1,677 Posted May 19, 2020 the standard red radio plug should have a switched live in it, have you checked the fuses? Share this post Link to post Share on other sites
gtiburge 0 Posted May 19, 2020 That’s what I thought from having other 205s I will check again , and I haven’t looked at fuses If I’m honest I no the main live has a fuse but the switched live would to ? I checked with a multi meter a few times but will have another look though Share this post Link to post Share on other sites
sport1901966 8 Posted May 19, 2020 I recollect having a similar issue - if I remember right, there is a light blue wire (29B maybe) that went to the Fuse board on a single pin connector to a terminal marked '+' which put out a permanent live, in the Haynes diagrams it looked like it should be switched, which when plugged into the terminal next to the '+' terminal on the fuse board (marked 'ACC') it then did operate as a switched live - maybe worth getting the multimeter on it and testing? Share this post Link to post Share on other sites
gtiburge 0 Posted May 23, 2020 Job sorted was exactly what you said thanks Share this post Link to post Share on other sites
