Daniel306
Xu10 8v Timing belt
Daniel306
What timing belt should I be using for a Xu10 turbo but fitted with the 205 8v head? Just removed a 114 tooth belt, but iv got a 113 tooth and unfortunately the timing mark on the belt is between the timing marks
xu10 is 11mm taller so I'd imagine you need the longer one
205freak
You need the 114 tooth one.
The mark on the belt is irrelevant.
