stu28stu 1 Posted April 11, 2020 Morning can anyone explain how/what changes i need to make to use lift reverse for a be1 1.6 gearbox, i am fitting a gti6 engine into my 205 , and cant get hold of a vts gearbox so i thought next best option would be a be1 1.6 gear box , only other boxes i have are for diesel engines. however the original engine was a 1.9 diesel so i dont have lift reverse set up , is it a simple job to change to lift reverse ? Its not going to be a daily driving so no motorway trips - she will be doing rallycross eventually. Share this post Link to post Share on other sites
welshpug 1,676 Posted April 11, 2020 you need the cable and the sleeve and collar from the gearstick. Also needs to be a late enough casing to have the crank sensor boss and hole in the top though! also a Bx 16v (1.9 mi16 clutch) the holes I think would be present also to swap the BE3 clutch arm from the Diesel box and use a post 1990 cable, the original diesel one will work. Share this post Link to post Share on other sites
barneys66 125 1 Cars Posted April 11, 2020 Hi Stuart - a bit off topic sorry, but if you happen to have any diesel boxes you're breaking then I'd be interested in a 0.76 or 0.81 fifth gear set if want to sell. Ta Share this post Link to post Share on other sites
stu28stu 1 Posted April 14, 2020 On 4/11/2020 at 11:00 PM, barneys66 said: Hi Stuart - a bit off topic sorry, but if you happen to have any diesel boxes you're breaking then I'd be interested in a 0.76 or 0.81 fifth gear set if want to sell. Ta HI Barnsey have a complete 1.9 diesel engine and gearbox spare ! Share this post Link to post Share on other sites
barneys66 125 1 Cars Posted April 14, 2020 Cool - let me know if you want to sell the fifth gear cogs separately (assuming they're either of the ratios above). Just need those two cogs, not the box. Thanks Share this post Link to post Share on other sites
