North
Lower dash trim drivers side.
North
Trying to get to the heater matrix. Could anyone tell me how remove the left hand part of the lower dash in the driver footwell? Is it separate to the main central front fascia. Phase 2 dash. Cheers
You don't need to remove it, you can get the matrix past it by gently bending the plastic a little bit. The Haynes manual will tell you to take the whole dash out to remove the matrix but it's a massive amount of work that you don't need to do.
North
Cheers.
