Ren89
SAD Unit connections
Ren89
Hi, can someone confirm which of these connectors is for the cool temp sensor on the SAD unit.
Cheers.
Coolant temp is the blue one.
Ren89
I thought it was just needed to be sure.
Also are the sensors round the back in correct positions can't remember which way round they go. DSC_0022.thumb.JPG.6687af0e0c34d1573e737ffa3c39ae5a.JPG
I can't remember which is which off the top of my head, it's easy to work out though;
If you touch each connector to ground one at a time either the coolant temp gauge will go to max or the coolant warning light will come on.
The larger sensor is the switch for the coolant light and the smaller sensor is for the gauge.
the original plugs pictured are colour coded, as are the sensors.
