stewartmichael
Slider pins 1.9 calipers
stewartmichael
Hello can somebody advise if these are the correct slider pins for a 1.9 front caliper. Replacement slider pins for the 1.9 don't seem to have the rubber on the end whilst the 1.6 does. The rubber boot had moved to the thicker side of the pin and had caused the caliper to stick.  Thanks
1.6 bendix caliper is VERY different, so there's no point comparing to the girling 1.9
stewartmichael
Hi Welshpug does that mean that the slider pins on arent the correct ones? The lower one has the rubber boot whilst the replacements don't. Can you tell from pictures if it is a 1.9 caliper?
farmer
I have tried pattern slider 1.9 pins from them and they do not fit in the past
