Junior1
TU Timing belt 995cc
Junior1
Hi all,
Just looking some advice on replacing my timing belt and water pump on my 1990 995cc. I'm new to Peugeots and have had a look through the Haynes book but is there anything I should look out for while I'm at it.
I keep seeing some stuff about the tensioner setting, something about a specialist tool? Can I just go 90 degrees with an Allen key and torque up the tensioner bolt??
DamirGTI
Of course you can .. people have been doing timing belts for ages like so , not only on PSA cars . No special tools needed really .
Lock the flywheel and camshaft pulley , fit the belt , apply tension to the belt until the belt can be twisted with fingers sideways at 45-90deg. in the middle on the longest side up front (between crankshaft and camshaft pulley)
I prefer to fit the belt and do it at around 45deg , as till stretch a bit over time ...
If you don't want to bother with locking the pulleys , use tippex and make a few marks on the pulleys-to-engine and on the old belt , then use those for reference when fitting new belt ...
Tippex is you're "best friend" when doing timing belts , even if you're locking the pulleys flywheel etc. , use tippex to be double sure that everything is aligned as it supposed to be .
When done , always spin the engine by hand few times to verify that there's no locking/binding (remove the spark plugs , it'll be easier to turn the engine by hand) .
Also i'd recommend replacing complete - belt , tensioner and water pump ...
One important thing with TU's - apply some medium thread lock compound on the belt tensioner stud , fit the nut and tight it (after you've adjusted the belt "by feel/deflection") ... as the nut which holds the belt tensioner on TU's had habit loosening off , and guess what happens then !
It's quick and easy engine to do timing belts , so no worries .
D
Junior1
Excellent, thanks very much!!
