Mid-life 205
TU3 water pump housing
Mid-life 205
Doing a refurb on my TU3 powered 205. I have a donor engine but it has evidence of a water leak where the water pump housing attaches to the block. I removed the housing on the donor engine and the o shaped seal looks like it is fibre not rubber.
I am not a fan of just adding goop and I cannot find a replacement part listed anywhere.
Suggestions?
DamirGTI
The black plastic housing right ?
Did an 1.3 Rallye and had the same problem , was leaking around the joint .. it's easy to break it as the plastic tends to get very brittle with age so , be careful .. common problem on TU's .
As far as i remember , there was rubber O-ring , not fiber one . I've broken off corners of that housing while trying to undo it from the block , so , got an aftermarket complete housing with the seal .
D
Mid-life 205
D
Nope.. that bit is fine.
Where the whole housing fits to the block. There is a fibre o ring and it leaks on both engines I have.
Mid-life 205
D
Mid-life 205
D
DamirGTI
I see ... that'll be this then :
http://www.miamistu.co.uk/pug/GB/205F/1/12A10A.HTM
... No2 - 5933 60 O-RING SEAL DIAM 36,5
Replaced that one as well when i did the last TU Rallye engine rebuild , used ordinary rubber O-ring and no complains nor leaks .
D
would imagine it was a rubber o-ring originally and its just dry rotted away.
its the same part number as the dizzy O rings on xu and tu engines, should still be available from a dealer as it was used on the ET3 water pump housing in the 207 and the TU3 in the Bipper.
Mid-life 205
D
Yup that's it!
Mid-life 205
Thanks Welshpug ordered one now so will clean up the surface and hope for the best. Easy to do a good job while it is on the garage floor but would hate to do it in the car.
Mid-life 205
Perfect!
Thanks for the help
