idoari
brake caliper and carrier grinding
idoari
Hi,
i am about to downsize my tires to the original size of 14" (from 15") and i have a bigger brakes install with 266mm discs.
the discs are not rubbing but the caliper is.
i was going to go on a route of wheel spacer but since i don't want to have the negative effect on the steering and suspension i decided to go on a different route.
i saw the the caliper is SLIGHTLY rubbing so i decided to shave it off a little and then paint it.
my brother is a little concern on what I've done (he is a mechanical engineer), he said the the brakes are designed on a specific  strength
but i think they always have a margin.
at the end of the day, i didn't have all that much (see pictures)
what do you think
thanks
Ido
Doseph
I've also had to take a grinder to fit my brakes over the wheels, i think i took more off than you as well....
Anyway the brakes have been on for months and have had no problems at all.
I get why your bro is concerned but i dont think Peugeot were "engineering" anything for strength back then, they just grab whatever is in the parts bin and throw that on :)
wicked
Think you're exaggerating a bit... They did calculate on what they were building, but you should see it in the 80's time frame with limited computing power.
With respect to the brakes; likely they are Bosch parts, so the math on the brakes themselves is done by the germans...
