Phil205 1 1 Cars Posted September 23, 2019 The garage have identified that the following need to be replaced. Does anyone know if the following can be bought or do they need be fabricated by the welder / Body Shop :- Both inner and outer sills Both rear quarter lower panels Both inner rear arches Both front inner arches and top mount panels Would anyone know any suppliers that I could try ? Share this post Link to post Share on other sites
Tom Fenton 1,555 Posted September 23, 2019 I've never seen a 205 bad enough to need all those complete panels. Usually it is small local areas that are needed, and a skilled repaired can make the sections. The only readily available panels are complete pattern outer sills, they fit OK when I have fitted them previously. Share this post Link to post Share on other sites
DamirGTI 345 Posted September 23, 2019 Me too ! guess it's a collision repair rather than rust repair ? If you can find any 205's at the scrapyard (3d base model will do) chop the needed bodywork parts off the shell and use those for the repair . New aftermarket parts , from what i've been working with "Klokkerholm" is somehow best for fitments/gaps etc. but much thinner than the OE panels .. and there's just the sills , door skin repair panels , and front sections which can be sourced new via aftermarked body parts .. the rest is pretty much OE stuff . As Tom said , repair panels sections can be made out of sheet steel too ... this is how i fixed mine . D Share this post Link to post Share on other sites
Phil205 1 1 Cars Posted September 23, 2019 1 hour ago, Tom Fenton said: I've never seen a 205 bad enough to need all those complete panels. Usually it is small local areas that are needed, and a skilled repaired can make the sections. The only readily available panels are complete pattern outer sills, they fit OK when I have fitted them previously. Thanks Tom, The garage suggested I check if I could source the panels. It is going to a (different) body shop on Friday so I can get their take on it. Both places suggested I check if replacement panels are available. I am no expert, but the rust looks quite bad. It's not been in an accident, just in need of a lot of work. I would like to get it fully road worthy, but might not be worth fixing ?? The bizarre thing is that it passed an MOT in August. They can't have checked it very well. Share this post Link to post Share on other sites
DamirGTI 345 Posted September 23, 2019 Can you make a few shots of these rusted areas ? Almost everything can be fixed bodywork wise , depending on how much you're willing to pay/invest in the repair .. if it's that bad , re-shell can be another option too . D Share this post Link to post Share on other sites
Phil205 1 1 Cars Posted September 23, 2019 1 hour ago, DamirGTI said: Can you make a few shots of these rusted areas ? Almost everything can be fixed bodywork wise , depending on how much you're willing to pay/invest in the repair .. if it's that bad , re-shell can be another option too . D I'll get some pictures on Friday and post. It looks quite bad to me. Share this post Link to post Share on other sites
Leslie green 116 Posted September 23, 2019 (edited) Arie plonk I believe now does the lower part of the rear 1/4 panel that joins on to the sill , as said a car that bad isn't really worth fixing as most have survived very well and a reshell as suggested may be the way forward with a good base 3dr shell . There are still loads of good cars out there might be best to get another and break /sell that one. Edited September 23, 2019 by Leslie green Share this post Link to post Share on other sites
Phil205 1 1 Cars Posted September 24, 2019 20 hours ago, Leslie green said: Arie plonk I believe now does the lower part of the rear 1/4 panel that joins on to the sill , as said a car that bad isn't really worth fixing as most have survived very well and a reshell as suggested may be the way forward with a good base 3dr shell . There are still loads of good cars out there might be best to get another and break /sell that one. Hi, Who is Arie plonk ? Share this post Link to post Share on other sites
Phil205 1 1 Cars Posted September 24, 2019 On 9/23/2019 at 3:51 PM, Tom Fenton said: I've never seen a 205 bad enough to need all those complete panels. Usually it is small local areas that are needed, and a skilled repaired can make the sections. The only readily available panels are complete pattern outer sills, they fit OK when I have fitted them previously. Thanks Tom, Where would I get complete pattern outer sills from, if we decide to go ahead ? Share this post Link to post Share on other sites
Leslie green 116 Posted September 24, 2019 (edited) Phil its Arie pronk sorry my bad spelling , he makes obsolete panels and can be contacted through face book under EMPA Peugeot 205 & Renault 5 gt turbo parts He lives in the netherlands but will post here no worries Panels for these cars are surprisingly scarse I found ,I know they don't rust that bad but are a fair age now where restoration is happening more and more . Eurocarparts used to do wings and front panels and bonnets but think the bonnets are obsolete now . Get some pics up see what you have ? Edited September 24, 2019 by Leslie green Share this post Link to post Share on other sites
Telf 227 2 Cars Posted September 26, 2019 (edited) Before any place tells you it's terrible and panels need replacement have a good look through the restoration section. You will see the common areas that need doing and be able to judge how bad yours really is. Edited September 26, 2019 by Telf Share this post Link to post Share on other sites
Phil205 1 1 Cars Posted September 28, 2019 (edited) On 9/23/2019 at 6:56 PM, Phil205 said: I'll get some pictures on Friday and post. It looks quite bad to me. Edited September 28, 2019 by Phil205 Share this post Link to post Share on other sites
Tom Fenton 1,555 Posted September 28, 2019 Not untypical. I’d say it’s had a bump at some point in its life for the headlamp panel to look like that. An easy repair if you have a spot welder, the headlamp panels are easily available. The inner wing is a common rot spot but again an easy repair, why on earth anyone would want to disturb factory seams is beyond me when all that is required is a nicely made repair piece butt welded in. Rear quarter is bad because someone has previously bodged it with filler. If it was repaired properly a few years ago it would not be bad now. The closing piece in the rear arch again is quite common but easy to repair. The hole in the sill is not as common but as said previously, the sill is available complete and again once the prep is done an easy panel to fit with the spot welder. None of that would phase me personally, but I cut my teeth on Minis, which often needed that kind of scale of repairs yearly for the MOT test. I would buy sills and a headlamp panel and repair the rest. Share this post Link to post Share on other sites
Phil205 1 1 Cars Posted September 28, 2019 (edited) 25 minutes ago, Tom Fenton said: Thanks Tom, Do you know where to get the sills and headlamp panel from ? Edited September 28, 2019 by Phil205 Share this post Link to post Share on other sites
Telf 227 2 Cars Posted October 1, 2019 Phil the damage to the sill and arch and 1/4 panel looks similar to mine- have a look at my Resto thread and it will show you the work required to repair it all. Share this post Link to post Share on other sites
