Kimsen
Rev Limit for an 1.9 Gti
Kimsen
After some struggle the car now runs fine , but it seems to not have a Rev limit it goes over 6900 so i was scared and stoped , i really dont know where the limiter should be but for an 8v mine its pretty high i think or im wrong? or did it goe to 7000?
That's too high, the standard rev limit for a 1.9 is about 6250RPM. A 1.6 goes to about 6750.
Edit: Don't trust the rev counter, they are notoriously inaccurate!
Edited by jackherer
Worth remembering though that rev counter accuracy can vary massively.
Also, if it's Jetronic then the limiter can be removed altogether by a quick ECU modification so it's possible (but unlikely) a previous owner has done that.
SRDT
Some "performance" ML1.3 chip remove the rev limiter by setting it around 15000 rpm.
Maybe yours was just set around 7000 by a guy that knew the ECU a bit better.
